YES, if you do it right. If you have a bunch of them, select a pair that have close output voltage values. Then you have to put a series resistor from each output to the load such that there will be about a 0.2V drop across it at full current.Thanks for the replays.
I have the same circuit on one of my data sheets.
But the question still remains, can you run 2 of them in parallel?
by Duane Benson
by Jake Hertz
by Duane Benson
