I have a vintage electronic chess board from the 1980's. Its 9VAC input. There is a quiet buzzing sound from the internal speaker. Its not too loud but I want to confirm that its nothing to worry about.
I checked all the grounds, electrolytic capacitors, etc. Is there something else I should be looking for? Also, the regulator gets pretty hot. I understand that its going to release excess voltage in the form of heat but other similar boards (different manufacturer) do not generate this amount of heat.
I was also wondering what the diode on the ground pin of the 7805 is for? And why the thin plastic in between the heat sink and chip? Shouldn't there be some thermal grease? This is a somewhat rare unit and difficult to replace. I want to do everything I can to insure its operating properly. Thanks!
