7660 ic uses
Discussion in 'General Electronics Chat' started by sukarthi, Feb 7, 2012.
  1. sukarthi
    Feb 7, 2012
    can any one tell accurate use of IC 7660 and where we have to use this IC
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    Once again....did u take ur medicine today....
    Seriously !! be clear in asking anything ..
  3. wmodavis
    Oct 23, 2010
    737
    150
    Where I have used it is to generate a low current negative voltage source where otherwise only positive was available. Read the data sheet. It has application suggestions. That is what they are for. Your own creativity is the other part of the equation.
    "where we have to use this IC?" You don't have to use this IC!
