7555 timer circuit
GopherT
Joined Nov 23, 2012
8,009
The 7555 should work the same whether 3v or 18V).
What voltage does your relay's coil need? What current?
Post a picture of your circuit (on the breadboard) - clear as possible.
Also, the 7555 can only handle 100 mA (in/out of pin 3) the 555 can work with 250 mA.
#12
Joined Nov 30, 2010
18,224
41.2 megs to a 33 uf? You are asking that capacitor to be a very low leakage capacitor! (146 nanoamps is the current flowing through the resistors with a 9 volt supply.) This is why we use counter chips on a short interval 555 chip.
34,468
I calculate 49.2 megs with 33μF to give a 27 minute time-constant or a timer period of over 29 minutes.
You will likely need very low leakage film capacitors (which are physically large) to achieve that period.
#12
Joined Nov 30, 2010
18,224
Yeah, 5 x 8 megs plus 6 times 0.2 megs = me getting old.:p
The fact that I can remember what I was thinking when I blew that calculation (about 100 minutes ago) is amazing in itself!
Wendy
Joined Mar 24, 2008
23,429
The 7555 has incredibly weak drive at lower voltages, it is proportional to the supply voltage. At 3V it is about 2-20ma, while at 15V it is nearer to 100ma. You have to allow for this weak drive when using this circuit with a much higher gain transistor, among other things.
A conventional 555 does not have this problem.
