74MHz FM transmitter
Discussion in 'The Projects Forum' started by Vincyoxy, Jul 23, 2009.
  1. Vincyoxy
    Jul 23, 2009
    Hi Expert,
    I doing a standard FM transmitter circuit.
    And it only can transmit in the frequency band of 88MHz to 108MHz which is radio frequency.
    But i want to make a tranmitter to transmit in 74MHz.
    I thinking to modify the tank circuit. But is it possible? Or other method to modify the circuit?
    CHEERS=)
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Do you have the schematic for us?
    Without the schematic it is more difficult to answer,
    as there are several types of oscillators.
    The frequency can be changed by tuning the circuits.
    Greetings,
    Bertus
    PS Is the 74 Mhz allowed for transmitting?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    I think 74MHz is in the FM broadcast band in Japan.
  4. millwood
    Guest
    you may want to think again on that.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    The question still remains, why 74 MHz?
    Model aircraft are on 72 MHz, surface models are on 75 MHz, and the Naval Observatory VLA is on 74 MHz to name just a few users in that part of the spectrum.
    The circuit to which I think you are referring can be tuned fairly broadly and potentially cause interference with any of the legitimate users.
    Thus, if you are not licensed to work on 74 MHz, I do not think this forum should support your effort to build such a transmitter.
    John
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    I was close but wrong.
    The FM broadcast band in Japan is 76MHz to 90MHz.
    It is 65MHz to 74MHz in former Soviet republics.
  7. DickCappels
    Aug 21, 2008
    2,768
    669
    Yes, if the frequency is determined by the tank circuit.
  8. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    If the transmitter has more stages, the amplifier stages will need adjustment too.
    You have not posted the schematic yet.
    Greetings,
    Bertus
