74LS390 Question
Discussion in 'The Projects Forum' started by bertz, Nov 11, 2013.
  1. bertz
    Nov 11, 2013
    238
    31
    I am using a pair of 74LS390 in a timer circuit configured to divide by 100. I will be using the 1Qd and 2Qd outputs. Do I ground the Qb and Qc outputs or leave them floating? Also should I ground pins 2 & 14 (CLR) since the oscillator will run all of the time?
  2. JohnInTX
    Jun 26, 2012
    2,393
    1,051
    The unused outputs (Qn) must be left unconnected. The two CLEAR lines should be ground (as CLEAR is active high and you are not using it).
    Depending on the application, you might want to incorporate a power-on clear to initialize the counters.
    Welcome to AAC and thanks for including the schematic with your question. That helps.
    bertz likes this.
  3. bertz
    Nov 11, 2013
    238
    31
    Thanks John!
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Never leave digital inputs open(not connected). As the result may be unpredictable. For TTL logic like your counter IC. Open inputs will take high level as a rule of thumb. But "noise" may change that. So any open input may behave unpredictable
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Unused INPUTS, as a general rule, should always have a current path to either Vcc/Vdd or GND/Vss, or unpredictable oscillations may occur, resulting in difficult-to-troubleshoot problems.
    On the other hand, unused OUTPUTS must always be left disconnected, or you will likely have high current flow, high power dissipation in the IC, and may very well burn it up.
    bertz likes this.
  6. bertz
    Nov 11, 2013
    238
    31
    Thanks Sarge
    Getting back up to speed- thanks for the refresher
    Bert
