74LS08
Discussion in 'General Electronics Chat' started by Linden, Feb 28, 2015.
  1. Linden
    Feb 28, 2015
    I am trying to use mini float switches to drive my inputs but when I hook up my Vcc and Gnd, they start off in a false logic "1" state.(measuring 1.4V on I and 3.9V on the O). What is going on? They are brand new chips.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    Can you post a schematic of your current set-up?
    Bertus
  3. Linden
    Feb 28, 2015
    JK is used as a piezo hush
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    I do not see any pull-up or pull-down resistors on the inputs of the gates.
    When you leave then floating the results may be unpredictable.
    Bertus
  5. Linden
    Feb 28, 2015
    I figured that would solve it just wanted to make sure. What size resistors would you suggest?
  6. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
  7. Linden
    Feb 28, 2015
    Thanks for all your help. I am sure this will work.
  8. MrChips
    Oct 2, 2009
    12,622
    3,451
    Unconnected inputs of TTL gates usually start out at logic 1. But it is better to be certain by using 1kΩ pullups.
    Roderick Young likes this.
  9. cmartinez
    Jan 17, 2007
    3,696
    2,748
    I normally use 4.7K, and up to 10K resistors as TTL pullups... is that bad? should I switch to 1K?
  10. MrChips
    Oct 2, 2009
    12,622
    3,451
    To answer your question, we have to look at the datasheets of TTL gates.
    For 74xx and 74LSxx, VIH is quoted as 2V. This is the minimum Vin for logic HIGH.
    Fro 74xx, IIH is 40μA and 20μA for 74LSxx. This is the input leakage current when Vin is HIGH.
    Suppose you want Vin to be 4V. Then the pullup resistor has to drop 1V while conducting IIH.
    Rpullup = (Vcc - Vin)/IIH
    For 74xx, Rpullup = 1V/40μA = 25kΩ
    For 74LSxx, Rpullup = 1V/20μA = 50kΩ
    Hence, Rpullup of 10kΩ is fine.
    cmartinez likes this.
  11. ScottWang
    Aug 23, 2012
    4,924
    776
    Your values of resistors are quite normal, if you want to reducing the current then you can increasing some more, normally resistor of pull high for TTL ic around 1K~33K, but if the pull low should be used 330Ω, because the internal diode of input, although using less 330Ω is ok, but it will draw more current.
  12. cmartinez
    Jan 17, 2007
    3,696
    2,748
    Thanks! ... Ah, the magic of datasheets... if only more of us bothered to actually read them... ;)
