I'm assuming this is a homework question (since it's in the Homework Help forum) so the intent is probably that you show that you understand where to get this information and not what the actual answer happens to be.i am having problems with this question mentioned below.
if applying an input waveform to the 74LS04 inverter, what are the maximum positive and negative peak voltages that should be applied?
please help.
by Aaron Carman
by Jake Hertz
by Jake Hertz
