74LS04 chip
jessi
Joined Apr 12, 2005
6
Can someone tell me what the recommended operating voltage for the 74LS04 chip is as well as what the maximum operating voltage is? I just started this Digital class and for some reason the book I have doesn't list this, even though it lists all the others....go figure???
beenthere
Joined Apr 20, 2004
15,819
The normal operating voltage for 74LS is 5 volts. My Signetics TTL manual says that it will go to 7 volts before the smoke comes out, but I'd get real nervous going above 6 volts. That's probably because I used straight TTL for so many years. The output current should not exceed 15 mills, too.
pebe
Joined Oct 11, 2004
626
[post=7934]Quoted post[/post]​
You can get a datasheet on this, or almost any other IC, from:
http://www.datasheetarchive.com/datasheet/pdf/2916.html
atferrari
Joined Jan 6, 2004
4,771
I always worked TTL and TTL LS with 5V nominal.
VERY SELDOM close to 5,25 V (probably once or twice) and quite often close to 4,85 V.
Nominal value is 5 V and there are lot of regulators available that bring you always there.
From all what I recall I've never worked above 5,25 V and I think there was a bad experience even there... and some warm feeling...
That's why I still love CMOS. But that is another story.
