74LS and 74HC Series
Discussion in 'General Electronics Chat' started by nDever, Jan 24, 2011.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey Guys,
    Will I be able to safely drive 74LS with 74HC series ICs and/or vise versa? I have read that the logic levels are not quite the same for both series ICs because the HC series is CMOS. How different are the TTL and power consumption levels?
  2. BillB3857
    Feb 28, 2009
    2,402
    348
  3. Ron H
    Apr 14, 2005
    7,050
    657
    The short answer is you can drive LS with HC, but the inverse is not true. 74HCT and 74LS are compatible in both directions. In addition, 74HC and 74HCT are compatible both ways.
    You have to be aware of fanout limitations in all cases.
    You should still read AN-319.
