74HC4052 Multiplexer/Demultiplexer
Discussion in 'Embedded Systems and Microcontrollers' started by MrL, Oct 24, 2010.
  1. MrL
    Oct 21, 2009
    46
    I'm currently working on a keypad circuit, in which a key press must be detected. The keypad is a 3x4 matrix. When a key is pressed, a 0 pulse will be sent to one row and one column.
    I was told that the 74HC4052 IC could be used to help with my circuit, but i'm struggling to grasp the concept of how it could be used.
    The following is a link to the IC's datasheet: http://www.datasheetcatalog.org/datasheet/philips/74HC4052N.pdf
    If anyone could point me in the right direction it would be greatly appeciated.
    Thanks.
    EDIT: Made a mistake in the title, should say 74HC4052
  2. MrL
    Oct 21, 2009
    46
    Would anyone be able to help please?
  3. ELECTRONERD
    May 26, 2009
    1,146
    16
    Why don't you just use a 74HC595 shift register instead?
  4. MrL
    Oct 21, 2009
    46
    It's required as part of my Uni project that i must use this multiplexer/demultiplexer.
    I was wondering what the z output would be if for example, the Y3 channel was turned on and was at a high state?
