74HC237
Discussion in 'General Electronics Chat' started by azngeek, Sep 16, 2008.
  1. azngeek
    Jul 22, 2008
    20
    Hi, just wondering for 74HC237 a 3-to-8 line decoder, it has a LE' and an E1'. So if I want to send a 0 to LE' and E1' respectively to set both LE and E1 to 1, would an open switch do, or would I have to specifically ground those pins?
    Thank you in advance. :)
  2. Externet
    Nov 29, 2005
    775
    57
    Can you rephrase please?
    What is 0 and 1 for you? --> low and high respectively ? Pullups/pulldowns work well.
  3. FunkiiMunkii
    Member
    Sep 16, 2008
    12
    The 74HC series are CMOS logic and thus the inputs cannot be left open. Therefore, an open switch won't work. Pull-up/pull-down resistors should be connected.
  4. azngeek
    Jul 22, 2008
    20
    Pull up, pull down it is. Thank you FunkiiMunkii!
