74F579 & RS232
Discussion in 'The Projects Forum' started by NcNghtStkr, May 13, 2009.
  1. NcNghtStkr
    May 13, 2009
    I have a project going where i have 4 groups of 3 74F579 Counters ganged together (24 bit count) I would like to send the count into my RS232 port for Data logging and conversion to Decimal display.
    Anybody got an idea on how to do this pure TTL? I realy dont have time (or funds) to learn a micro at this time so TTL would be prefered in the short term, if it can be done
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yeah. You build the transmit half of a UART, which is a 10 or 11 bit shift register. Then you need a clock genertor to generate the baudrate and a state machine to take the three bytes from the counter, jam transfer them to the shift register, and clock the register 10 or 11 times. Last but not least you'll need a logic level to RS-232 level shifter. Maybe they still make the AY-3-1013(?) UART or maybe they don't. If they do it might be helpful.
    What a hoot that you think this is the easy way to go. I'm ROTFLMAO.
  3. NcNghtStkr
    May 13, 2009
    Ok, that gives me some ideas to play with in the morning.
    I didn't say easy, just don't have time to learn micro right now. will have plenty of time later if the economy don't come back :p
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If I was actually going to do this I would do it in an FPGA probably using VHDL. Thing is, learning VHDL is probably more difficult than learning C for a microcontroller. At least I thought it was.
