7447 Troubleshoot
Discussion in 'General Electronics Chat' started by salabaal, Apr 25, 2010.
  1. salabaal
    Apr 25, 2010
    15
    I have been working on a timer project with LED display.
    On friday, I got to see some numbers display on my dual 7-segment display. I must have made a few changes, but since yesterday, I can't seem to figure why my 7 segment display LED doesn't lit.
    I verified my connections, did some troubleshooting with the input to make sure that I was receiving signals in, but NOTHING COMES OUT THE OUTPUT, using the truth table.
    PLEASE HELP!
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Do you have a schematic?
    The photo is rather dark, can you make a clear picture of it?
    Bertus
  3. salabaal
    Apr 25, 2010
    15
    Here is a better picture.
    I have a similar schematic in the same breaboard for a switch to resitor to 7447 to dual display 7 segment LED display, but neither works!
    My LED doesn't lit at the output, but I do have input signals on my input.
    Your help is greatly appreciated
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Where is the 7 segment display?
    Are legs of the resistors on the bottom not touching eachother?
    Bertus
  5. salabaal
    Apr 25, 2010
    15
    Instead of jumping to a 7 segment display, I am using an LED to check my ouput.
    I have by passed this step because my 7 segment display wasn't lit.
    Below is the other diagram I have going for the switch to LED display, that too doesn't work.
    If I find the answer the problem 1 than I can save problem 2.
    Thanks for your time!
    Salab!
  6. salabaal
    Apr 25, 2010
    15
    And by the way, all my connections are clear of each other. I did a double-check.
    Thanks Salab!
  7. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Is the display common cathode or common anode?
    I see the display is connected to ground (if the blue line is ground).
    As far as I know the display should be common anode with resistors for each segment and the common connected to the plus 5 Volts.
    Bertus
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    The ground wire to your 74LS74's ground pin appears to connected to +5V.
    hgmjr
  9. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  10. salabaal
    Apr 25, 2010
    15
    So again, where does the common anode connection goes?
    That's the only connection I don't have right now on the LED schematic.
    Second, what happened to the 7447 circuit I sent earlier, any idea why my LED doesn't come on.
    HGMJR, I fixed that, but my segment doesn't lit, so I am guessing that I need to do something with the common anode pin.
  11. salabaal
    Apr 25, 2010
    15
    Bertus,
    I see that you answered the first question. Sorry for the misunderstanding.
  12. retched
    Dec 5, 2009
    5,201
    313
    Common anode goes to V+
  13. salabaal
    Apr 25, 2010
    15
    I have done that:
    Connected LT (pin 3) to ground - > that is the only way I can get the LED the display
    RBI (Pin 5) and RBO (Pin 4) don't really care. They are at ground.
    I have a "C" displayed now. That's a good start, since I wasn't seeing anything at all.
    However, the "C" wouldn't change if I play with my switches.
    Does anyone know why?
    Sala
  14. hgmjr
    Jan 28, 2005
    9,030
    214
    Do you have a circuit diagram that you can post? It is painful to try to figure out how the circuit is connected up just be looking at the photo.
    hgmjr
  15. salabaal
    Apr 25, 2010
    15
    I agree but honestly,
    i have pictured the schematic in my head. I do not have one specific schematic to work from because there is none out there that utilizes my parts, at least that I could find, so I am using the datasheets from each component to make up the assembly. I wish I could hand sketch this circuit, but I don't have the tools either to scan it.
    I hope this will help:
    - 6 set of switches, but only using 4
    - Off end of switches all connected to +9V
    - ON end of switches connected to A, B, C and D of the SN74LS47N Chip
    - Pin of 7447 connected to ground and Pins 4 and 5 connected to +9V
    - Pin 16 of 7447 connected to +9V and Pin 8 connected to Ground
    - Pins 10 through 15 connected to dual display Seven Seg LED using 470 Ohm resistors
    - Pin 14 of seven segment connected to +9V and Pin 4 Connected to Ground
    Now that I think of it, is 9V too much to send to this circuit?
    Sala
  16. retched
    Dec 5, 2009
    5,201
    313
    Yes. Yes it is.
    You have the data sheet linked in your last post. In it it says MAX 5.25v
    PAGE 9.
  17. salabaal
    Apr 25, 2010
    15
    Thank you. Thank you!
    Your strategy helps identify the problem
    Now, I have a voltage regulator, does anyone know how I would use this with my 9V battery.
    Thanks again for your help.
    Salab!
  18. retched
    Dec 5, 2009
    5,201
    313
    Which regulator do you have?
  19. salabaal
    Apr 25, 2010
    15
    I am using an NTE960,
    and I tried connected pin 1 of the regulator to the +9V of my battery,
    Pin 2 to the - negative terminal of my battery
    Pin 3 back to my circuit, and Pin the regulator to the negative terminal of my circuit.
    It still doesn't work!
    I am still getting the BIG RED "C" on my 7-segment display again!!!
    Salab
  20. salabaal
    Apr 25, 2010
    15
    This should be a piece of cake.
    Why am I not there yet???
    Please help!
