741 opamp data sheet help
Discussion in 'Homework Help' started by Random3s, Nov 2, 2014.
  1. Random3s
    Jul 30, 2014
    38
    I am writing a report concerning inv and non inv op amps. The inverting op amp circuit was 18v, + or - 9v and the amp was able to swing within a couple of volts to the supply rails, at around 7v max. I understand this is usual behaviour for 741 op amps, but would like to know what its referred as on the data sheet. Below is a link to the 741 model iam using, but I cant find anything in the sheet to confirm this behaviour. I am not sure it would be enough to state that "commonly 741 opamps are able to swing within a volt or 2 of the supply rails".
    Thanks in advance.
    LM741 data sheet
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Read the fairchild datasheet.
    There is this graph given:
    Bertus
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
  4. Random3s
    Jul 30, 2014
    38
    Thanks guys, so the voltage output swing is provided as a ratio of a given supply to a set RL value. In this case is RL the feedback resistor, from the output back to the inv input? (standard inv and non inv amp config)?
    Could someone also point me in the right direction with regards to the bandwidth of a 741, there isnt a badwidth stated in the data sheet, but my project build had a break freq of 6kHz.
    thanks again
  5. shteii01
    Feb 19, 2010
    3,500
    511
    Normally RL is LOAD RESISTOR, from output to ground.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    The philips datasheet has a graph for the frequency versus gain:
    Bertus
  7. shteii01
    Feb 19, 2010
    3,500
    511
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, without RL resistor, feedback resistor is a load for opamp
    Well, the data sheet give as Gain bandwidth product = GBP and additional if we know the voltage gain we can find breakdown freq.
    For example for non-inverting amplifier with gain equal to 10V/V we have
    Fc = GBP/10 = 1MHz/10 = 100Khz but for inverting amplifier with a gain equal to -10V/V we have
    Fc = GBP/( 1 + |10|) = 1MHz/11 = 90.9kHz .
    And for voltage follower we have
    Fc = 1MHz/1 = 1MHz but for inverting amplifier (gain -1V/V) we have Fc = 1MHz/ (1 + |1|) = 500KHz
    Of-course this is true only if we have no capacitors across Rf resistor or parallel to the load resistor.
  9. Random3s
    Jul 30, 2014
    38
    Great, thanks for your help guys, much appreciated.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    For the data sheet you linked in the OP, there is a line for Output Voltage Swing that lists the swing for various supply voltages and load conditions. It also supplies a bandwidth spec based on rise-time measurements (be sure you read the Notes in datasheets). This is most likely the gain-bandwidth product for an opamp.
