741 Op Amp follower -- time delay?
Discussion in 'General Electronics Chat' started by Tom1962, Sep 24, 2012.
  1. Tom1962
    Sep 10, 2012
    19
    If I use a 741 op amp as a voltage follower for a 12vdc pulse, will the output pulse lag behind the input by a measurable amount of time?
  2. Dodgydave
    Jun 22, 2012
    5,172
    778
    can you post a diagram?
    i would not use a 741 they are out of date...
  3. ramancini8
    Member
    Jul 18, 2012
    447
    119
    The slew rate on a 741 is very low, so the pulse may be gone before 741 reacts. Please the pulse width you want too detect, and a schematic of the proposed circuit so we can comment.
  4. Tom1962
    Sep 10, 2012
    19
    I have a quick occassional 12vdc pulse from an existing circuit which this circuit should change to 5vdc and hold a bit longer so it can be logged and light warning LED. See circuit below. All tips welcome, but in particular trying to figure out which op amp (or dedicated buffer) and inverter to use on the input line, since the pulses are only 3 or 4ms. I'm worried that a 741 or similar will be too slow to act as a good buffer for such a fast pulse. Also not sure which inverter to use on the input since the 555 triggers on low rather than high.
  5. ftham
    Jan 18, 2008
    If we look at the datasheet for the 741, we'll find that it has a minimum slew rate of 0.3V/uS. Which means that it will take up to 40uS to slew from 0V to +12V, then it will take another 40uS to slew from +12V to 0V. What this mean is that the minimum pulse width need to be at least 80uS.
    Please note that the output of the 741 can only swing 2V from the rail, so if supplies were connected to 0V and +12V, the output is limited to +2V to +10V.
  6. Tom1962
    Sep 10, 2012
    19
    Thanks, is there an Op Amp or dedicated buffer that can act as a buffer/follower for such a fast pulse?
    In the meantime, I'll have to google "slew rate"...
  7. ftham
    Jan 18, 2008
    Since we are only trying to generate a square pulse it might be better to use a voltage comparator (even though they are slightly more expensive) rather than an opamp. There are several reasons for this you can find details at http://www.analog.com/library/analogdialogue/archives/37-04/comparator.html.
    Slew rate (Large signal) is similar of rise time (small signal). Though rise time is directly proportional to the Gain Bandwidth Product GBW, Slew Rate has no relation the GBW at all.
    As to which comparator to use, just use one that suffice for your application, eg LM311.
  8. Dodgydave
    Jun 22, 2012
    5,172
    778
    Use a CD4069 as the inverter input to the 555.
    http://www.fairchildsemi.com/ds/CD/CD4069UBC.pdf
    and use a CA3240e dual op amp, which as a slew rate of 9V/uS
    http://users.rowan.edu/~jahan/ECT/ECT_2007/presentations/324-opamp.pdf
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    Look at the datasheet for the ordinary NE555 or are you using a Cmos 555?
    With a 12V supply, the output high of an ordinary NE555 is +10.65V, and lower if it has a load, not 12V. A Cmos 555's output goes to +12V if it has no load.
