741 Electret Pre-Amp
Discussion in 'General Electronics Chat' started by Razor Concepts, Jan 22, 2009.
  1. Razor Concepts
    Thread Starter Active Member
    Oct 7, 2008
    212
    I want to make an electret pre-amp as a sound sensor for a microcontroller. Here is a circuit I found:
    I don't need precision, I just need to tell the difference between loud noise and soft noise - will this circuit do the trick? I also have a lm311 lying around but I'm thinking that the 741 will be good enough. Thanks!
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    I don't seem to be able to open your attachment.
    hgmjr
  3. Razor Concepts
    Oct 7, 2008
    212
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It should amplify. How are you going to indicate loud and soft?
  5. Razor Concepts
    Oct 7, 2008
    212
    I will be using a 10 bit ADC. I think 5v over 1024 is a 5 millivolt resolution.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You could rectify the sound to DC and use a voltage comparator. If you still go with the ADC, it will still be a good idea to rectify the output.
  7. italo
    Nov 20, 2005
    205
    I don't see a preamp i see a lousy switch. A comparator will do you more good.
  8. flat5
    Nov 13, 2008
    403
    17
    You get what you pay for?
    There is no base bias on the transistor.
    Not a great circuit. You can find a better one...for free.
  9. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    The lousy old 741 opamp is too noisy (hisssss) to be a mic preamp.
    The circuit with the 741 and with the unbiased transistor on the right side is a joke. It shows a 3-wire electret mic that is very rare. A 741 is spec'd with a 30V supply and most will not work from a 5V supply.
