"72W SMPS DESIGN -Help Needed"
Discussion in 'The Projects Forum' started by mishra87, Jul 18, 2016.
  1. mishra87
    Jan 17, 2016
    202
    I want to design SMPS under below specification-
    1. Input - Universal 85-265VAC, 50Hz
    Output- 24V@3A
    2.
    Output- 36@3A
    Please help me design it.
    Can anybody share me schematic or reference design .
    Thanks in Advance !!!
  2. tcmtech
    Nov 4, 2013
    2,108
    1,747
    Buy one. It will be cheaper and faster plus it will be reliable too.
    absf, AlbertHall and mishra87 like this.
  3. Sensacell
    Jun 19, 2012
    1,183
    276
    Agreed- buy one.
    The design of a good SMPS is a non-trivial effort.
    mishra87 likes this.
  4. mishra87
    Jan 17, 2016
    202
    If it is an application specific even then i should buy ?????
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes -- absolutely.
  6. mishra87
    Jan 17, 2016
    202
    I think nobody interested on this my post to help me out....!!!
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I don't know how you can say that. We have tried to give you the best possible advice. You can take that advice or ignore that advice as the mood moves you. It is however rude and disingenuous to complain that nobody is interested in your post. If you were an accomplished circuit designer and had awesome technical and construction skills then perhaps your goal of constructing an SMPS would seem more reasonable. If you still want to do that you're going to need to learn a few things and you're going make mistakes that result in producing magic smoke.
  8. tcmtech
    Nov 4, 2013
    2,108
    1,747
    Well if you want help tell us what you are using it for and why you think it that needs a specific custom power supply otherwise if all it needs is a 24-volt source that can supply up to 3 amps then a common off the shelf unit will work just fine.
    Lack of sufficient information on your part leads to lack sufficient replies on our part. :rolleyes:
