By providing sufficient details..i have made 24 vdc regulator to get 24 vdc regulated output with the help of ic LM7824.
how can i make regulator for 72 vdc & 110 vdc?
input ( for both 72 & 110 vdc out put ) is 230 volt acBy providing sufficient details..
Input voltage?
Current requirements?
pl. clear that i have already 0-230 vdc 4amp. capacitor input (pai) filter variable power supply.I was about to suggest the TL783 too -a wonderful high voltage solution, then I re-noticed the input voltage (230 VAC), which would be a problem. Also, the current is pretty high for such a large input to output differential, meaning hundreds of watts would be lost in dissipation.
That brings us to a switching power supply. One of the better choices for this kind of power level is the LinkSwitch line from Power Integrations.
https://ac-dc.power.com/products/product-archive/linkswitch/
I would consider breaking the project up into two separate power supplies, particularly if the outputs are to be isolated from theline or ground, unless you have a very strong transformer design background.
in ur suggestion current seems to very low. pl. clear that i have already 0-230 vdc 4amp. capacitor input (pai) filter variable power supply.See attachment.
by Jake Hertz
by Jake Hertz
by Jake Hertz
by Don Wilcher
