I'm designing a tube preamplifier & I want to add a volume counter.
I'm a complete novice so I want someone to help me with it.
The volume pot is a 250K which has 40 small divisions.
As I cant use any signal from the amp to drive the LED counter I thought of a couple of ideas: To make a kind of ohm-meter circuit connected to either the volume pot or to another VR mechanically connected to the volume pot to avoid signal interference.
The second idea is to fit a shaft extention to the the volume pot which magnitically activates a (solenoid???) switch.
I also need to know how to calibrate the counter for the required reading ie. from 0 to 40.
Please help, thanx
Please help, thanx
