7 segment to matrix decoder
Discussion in 'General Electronics Chat' started by richard3194, Nov 28, 2015.
  1. richard3194
    Oct 18, 2011
    65
    Hi. Is there such a product as a 7 segment to matrix decoder?
    EDIT: I mean, a decoder that would take 7 segment data, and energize only one led at a time in a matrix array.
    EDIT: Actually, when I think about it, it's not that I need a matrix decoder as such, what I do need is a decoder that will take 7 segment display and produce an output on a single line. So, 7 segment data would go in, and the output would be a 10 line output, only one line HIGH at any one time.
  2. Brevor
    Apr 9, 2011
    282
    56
    No, no such device. You would have to make one.
  3. Dodgydave
    Jun 22, 2012
    5,150
    769
    Tell us what you're using it for, maybe you can use the binary inputs of the segment drivers, to give you that result, otherwise use a microcontroller to reverse the process.
