7 segment problem proteus
Discussion in 'The Projects Forum' started by MrYu, Jul 11, 2012.
  1. MrYu
    Sep 26, 2011
    42
    how to fix 7 segment in isis , it won't appear it's value in ARES even i fix the packaging and set the footprint in ISIS
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    Model it as separate LEDs instead of a display? Not sure what you're trying to accomplish...
  3. absf
    Dec 29, 2010
    1,493
    374
    I created a simple 2 chips design and I have no problem with the PCB.
    Did you uncheck the box "Exclude from PCB Layout"?
    Allen
    MrYu likes this.
  4. MrYu
    Sep 26, 2011
    42
    yeah it works fine now i uncheck the exclude from PCB layout
  5. MrYu
    Sep 26, 2011
    42
    i have another problem in actual building of this circuit when i test the pin QA to QG of 7448 IC in multimeter,. i only get 1.5v and sometimes just 1v. i bought it a while ago. is it possible that the IC is broken?
    http://imageshack.us/photo/my-images/705/95525217.jpg/
  6. MrYu
    Sep 26, 2011
    42
  7. absf
    Dec 29, 2010
    1,493
    374
    From my datasheet the 74148 can only source 800uA and sink 16mA. The 74LS148 can source 400uA and sink 8mA. (I dont have the datasheet for 7448).
    That's why the voltage dropped so much when you're sourcing them directly from the outputs. Try inverting the outputs using inverters or inverting buffers to the 7 segment CA LED. It should improve the situations of the 7448.
    Allen
    MrYu likes this.
  8. MrYu
    Sep 26, 2011
    42
    yeah i think i found the answer your right.. but what in the world the storekeeper give me
    7447 and i get CC 7 segment. maybe she doesn't know 7447 can't replace 7448 ?
    i'm working this for about 5hrs and tnx i get a lot of knowledge here :D godbless
    http://forum.allaboutcircuits.com/showthread.php?t=36168
