Hi, and thanks for you time in advance.
In my pickup truck, I have a 6 position switch that I use to control the aftermarket "chip" for my trucks performance and towing.
I have enough electronic knowledge to read a schematic, but not enough to make my own.
Here is the problem. There is no way to identify what position I am in while driving down the road. I have been looking online everywhere to try to find a 7 Segment LED "driver" to work with a 6 position switch.
I have found this schematic from a previous post, and think it would work. My question is, can I delete positions 7-12 by just unhooking all the wires attached to those positions?
I will be working with 12VDC, and I am also not sure of the voltages needed at the parts, or the resistors needed to make the correct voltage. If someone has anything like this lying around, or any better ideas than this, please let me know.
Any help would be greatly appreciated
Thanks You
Stephen
Thanks You
Stephen
