Since the LEDs would be in parallel (not series) of the 9V battery, the resistor values remain the same.If I were to use two single digit LED's driven by the same 9V battery, should I lower the resistor number, or leave them at 1k?
For wire, I suggest 26 awg stranded, but 24, 28, or 30 would also work.
It will do, but if you are going to buy only one color, you might choose white, so you can use a sharpie to add coding marks to the wire.Oh, must of overlooked that. Thanks!
Would this here be good:
http://www.ebay.ca/itm/100x-Black-1...omain_0&hash=item1e709a4a3b#sfmsg_-7890|0|0@@
There may be easier ways such as using solder lugs. You'll want to be able to remove the battery pack from the other wires so you can charge it and disconnect it quickly in the event of a problem.Hey, this might sound crazy, but I was just wondering if it was okay to solder 66 wires (both positive and negative) to one of these battery packs? Or would that be too much?
by Duane Benson
by Jake Hertz
by Jeff Child
