7 segment interface with PIC controller
Discussion in 'Embedded Systems and Microcontrollers' started by ect_09, Sep 29, 2014.
  1. ect_09
    May 6, 2012
    180
    can i connect 7 segment directly to PIC controller ??
  2. tshuck
    Oct 18, 2012
    3,531
    675
    In general, yes.
  3. MrChips
    Oct 2, 2009
    12,636
    3,455
    But it would be wise to put a resistor in series with the PIC output in order to limit the output current.
  4. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Most PICs sink/source 25ma which is enough for segments.
    For common-cathode, drive the segments (1=on) through resistors. Digit select will usually require a transistor to sink all of the segment current.
    You will have to write firmware to multiplex the displays for more than a few digits.
    This thread and others on AAC have lots of information and code.
    Good luck.
    EDIT: MrChips and tshuck type faster than I do..
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
