7 segment display
Discussion in 'Programmer's Corner' started by hami007, Jan 18, 2009.
  1. hami007
    Oct 26, 2008
    14
    hello i need a program in assembly( tasm)
    Use the lower 4 bits of the pc parallel data port and connect it to the seven segment display inputs. The input A is the least significant bit, and input D is the most significant bit. Use the upper 4 bits of the data port and connect to the socket for the second seven segment display.
    Make a two digit up counter using two 7-segment displays
    what would be the logic for up counter from 00 to 99 as i am using a BCD decoder
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Please discontinue your practice of starting the same thread. If you have not received an answer to your request then most likely there are no forum members that feel comfortable enough with TASM to reply.
    hgmjr
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The programming is up to you. Here is a link to how to use the printer prot that should answer all your questions - http://www.beyondlogic.org/ecp/ecp.htm.
    You absolutely must understand the hardware before writing code.
