7 segment display with 8051
Discussion in 'Embedded Systems and Microcontrollers' started by sandy12cass, Jul 15, 2010.
  1. sandy12cass
    Jul 8, 2010
    can you pls. help me regarding in my project...
    i want to display the digits 0-9 in seven segment using keypad with the use of 8051 i.c
    ... thanks a lot guys :)
  2. sandy12cass
    Jul 8, 2010
    also can i get also the schematic diagram of that circuit??
    pls... hope u can help me guys :)
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Welcome to the forums. I moved your posts to their own thread, as the one you hijacked was not related.
    Is this a "straight" 8051, or one of the later microcontroller variants? You might do a forum search on interfacing keypads and displays.
  4. Arm_n_Legs
    Mar 7, 2007
    183
    10
    Which 8051 are you using?
  5. Harrington
    Dec 19, 2009
    86
    Think about this now Numbers 0 to 9 first of all what is it ??
    How is your keypad laid out ??
    Then think matrix theory perhaps ??
    Columns and Rows ? Yes , No
    Then what do we think ?? How to connect this to a port
    So we are going to switch each column line on in turn and then see row we get a reading from
    Basic algorithm for doing this would be What ??
    If (( Column 4 ==1 ) And ( Row4 == 1))
    Then Button F pushed Value = decimal 15
    So start from there first drawing your hardware diagram connection to processor ports then we think about what BCD " Binary coded decimal " maybe
    So we have to do what Draw up a truth table
    15 in decimal is FF in hex is 0000 1111 binary 8 bit unsigned
    table will be something along the lines of port pins (representing our segments ) mapped to decimal display Correct ?? Yes or No
    So we need to draw a circuit showing this + connections to 7 Segment display and keypad
    Finally implement a look up table which is going to be an array of some type index corresponding to decimal picked up by switch pressed with value in binary output to port
    Flow chart or basic English algorithm showing us how we intend to do this
    + Code for the processor written either in c or may be even better still assembler
    Best way to start something like this What do you think ??
