7-segment display counter
Discussion in 'The Projects Forum' started by KMK, Feb 12, 2010.
  1. KMK
    Thread Starter Active Member
    Feb 11, 2010
    68
    Hello!
    I'm new to this forum & electronics.
    I plan to create a counter using 555 timer. I intend to use 4026 which has a BCD counter & lcd driver. I am using a common Anode display with a decimal dot.
    could you please help me with this & let me know if I can use the 4026 with the display. If not, which other IC can I use?
    Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The device is active low, so it will work with common anode displays. Get the data sheet to see the functions.
  3. KMK
    Feb 11, 2010
    68
    Thanks for that information, Beenthere.
    also i woukld like to know if single resistor of 470 ohms is sufficient connected to the anode, or if indivisual segments need to have indivisual resistors?
    thanks
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It is necessary to use resistors for each segment.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
  6. KMK
    Feb 11, 2010
    68
    thanks for that information guys.
    could you also help me with correct part # for the folling chips? I am not able to identify them.?
  7. KMK
    Feb 11, 2010
    68
    they seem to have # 7533 & 8907, but still am confused. also im not able to upload the images for same.
  8. retched
    Dec 5, 2009
    5,201
    313
    To attach images, click (go advanced) and scroll below your post to (Manage Attachments). That will pull up a window that will allow you to add images to your posts
  9. KMK
    Feb 11, 2010
    68
    thanks. let me check.
    ok. got it. will uopload imageslater
    thanks again .
  10. KMK
    Feb 11, 2010
    68
    fimd the images pls
  11. KMK
    Feb 11, 2010
    68
    still cannot upload images. gives blank page with diagnose connection problems
  12. KMK
    Feb 11, 2010
    68
    finally got hte images uploaded. pls help me with these chips.
    thanks again.
