7 segment counter, sequence:13567-13567 and so on
Discussion in 'Homework Help' started by B-Sparkes, Dec 30, 2010.
  1. B-Sparkes
    Dec 28, 2010
    I wonder if anyone can help me with this one?
    I have to design a counter using flip flops to display on the seven segment display unit: 13567-13567 and so on.
    I have to build it on multisim so what would i need to do this:
    How many flip flops and what types?
    what and if any gates would i use and what type?
    and how would i build this?
    If you can help me on this i would be very grateful?
    Brian
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Does that mean the count goes 1, 3, 5, 6, 7 and back to 1?
    How many flip flips does it take to indicate the value of 7 in binary? Can you make a counter with flip flips that goes 0 - 7?
  3. B-Sparkes
    Dec 28, 2010
    Yes, im looking for a circuit that i can build on multisim that will produce one of these sequences:1 3 5 6 7 1 3 5 6 7 1 3 5 6 7 1 3 5 6 7 , 0 2 3 4 6 0 2 3 4 6 0 2 3 4 6, 2 4 6 0 7 2 4 6 0 7 2 4 6 7 0 etc exactly one of these would be perfect!
    Brian
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Since there is only one "jump" in the sequence, you can do the following:
    Have a counter count from 2 to 7 and pass the result through a logic circuit that recognises the binary 2. Activate a quad 2-to-1 MUX with that result.
    If the 2 is present, have the MUX conduct a constant binary 1. If not, have it give the result of the counter unaltered.
    Is that clear?
  5. djsfantasi
    Apr 11, 2010
    2,907
    879
    There is a jump at 4 as well... But the same solution for jumping the 2 count can be applied to the 4 count...
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    Well, yes and no:
    You can wire the 4 so that it shows 3 or 5, but then that number will be displayed for 2 clock cycles.
    Since there are two jumps I think it is convenient now to build an FSM, or use 3 8-to-1 MUXs along with a counter to build the sequence.
