7 LED chaser slightly modified
Discussion in 'The Projects Forum' started by Tony Spence, Dec 20, 2013.
  1. Tony Spence
    Dec 20, 2013
    63
    I have built a 7 LED chaser circuit running on 18V. I changed one LED for a copper coil to run an electromagnet but it didnt have enough power, then i added a darlington pair I had from the early 90's never used before the same output and it worked for a bit i added a switch so it could be turned on and off but after a few days it had stopped working.
    So i changed the output back to an LED and still didnt work then i changed the two old school transistors for more recent ones four different ones of the same type and model, the lights work but when the coil is put back i get nothing from the coil but the rest of the lights still light up in their order.
    Is there a way to boost the current like a replacement transistor for the darlington pair ( both BC108C's )without increasing the voltage to the circuit?
  2. tubeguy
    Nov 3, 2012
    1,157
    197
    What current is needed for the coil?
    Or, what is the resistance of the coil?
    Did you use a snubber diode across the coil?
    What chip is used to drive the LED's?
  3. jayanath
    Dec 11, 2010
    17
    I have following code. but all leds are fading and getting on together. no running action. how can i make chaser action with fading effect. i mean comet tail. pls help me?
    #include <pic.h>
    #define FADE_RATE 12
    #define INITIAL_WIDTH 128
    void fade()
    unsigned char rate = FADE_RATE;
    unsigned char pulse_width = INITIAL_WIDTH;
    unsigned char count;
    while(pulse_width){
    PORTB= 0b11111111;
    for(count=0; count<pulse_width; count++){
    asm("NOP");
    PORTB=0b00000000;
    for(; count; count++){
    asm("NOP");
    if(!rate--){
    pulse_width--;
    rate = FADE_RATE;
    int main(void) {
    char b;
    TRISB = 0b00000000;
    while(1){
    for(b=0x02; b; b<<=1){
    PORTB = b;
    fade(b>>1);
    for(b=0x40; b; b>>=1){
    PORTB = b;
    fade(b<<1);
