7.4V Li Ion battery charging from USB
Discussion in 'Electronics Resources' started by Cukrai, Oct 22, 2014.
Thread Status:
Not open for further replies.
  1. Cukrai
    Nov 9, 2013
    13
    Hello everyone!
    In my project I want to use a battery like this http://uk.farnell.com/bak/18650ca-2s-3j/battery-lithium-ion-7-4v-2250mah/dp/2401854 2 cells Li Ion battery pack. And i want it to be charged from USB port. Is it even possible to do that? Because USB output is 5V, and when charging a battery like this, do I need a charger circuit that can supply 4.2V and it charges each cell independently? Or both cells of this battery has to be charged at the same time, so it means that I need an input to the charging circuit bigger than the batteries voltage and I cant charge it from USB port?
    Thank you! hope you understood my question :)
  2. ScottWang
    Aug 23, 2012
    4,933
    777
    You need a mc34063 dc to dc converter to converting 5V to 8.4V, or using mc34063 dc to dc converter to converting 5V to 12V and using Lm2576HV-adj to adjust to 8.4V.
  3. Cukrai
    Nov 9, 2013
    13
    This is something what I was looking for! But don't I need an IC to charge a Lithium Ion battery? that controls charging voltage, current and prevent it from overcharging?
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes, you do need an IC to charge a battery. If the charging source has a lower potential than the batteries you may need more than one. The suggested DC-DC converter is designed to produce a charging voltage that is higher than the battery voltage. What exactly were you expecting?
  5. Cukrai
    Nov 9, 2013
    13
  6. ScottWang
    Aug 23, 2012
    4,933
    777
    If you want to choose MCP73864 to replace Lm2576HV-adj, that's ok, but you still need to use mc34063 and then connecting to MCP73864.
Thread Status:
