7.4 Chapter Trouble
Discussion in 'General Electronics Chat' started by martin1512, Apr 17, 2011.
  1. martin1512
    Apr 17, 2011
    Hi, I am reading the textbook about DC circuits from this page. Its awesome but I think i found some nonsence. (I also think this was discussed here on this forum but I havent found it).
    So, to the problem.
    I am currenty on 7.4 chapter - COMPONENT FAILURE ANALYSIS
    The textbook shows there example of 4 resistors connected like this : (R1//R2)--(R3//R4). We are solving what happens when R2 fails.
    So the total resistance of R3//R4 is same as they are working as before. Trouble is that when R2 burns we have only R1. The textbook says that the total resistance of R1//R2 is lower after R2 burns. But I think its not true. Cos when 2 resistors are in parallel the total resistance is lower than value of the lowest resistor.
    And when 2 is turned off the total resistance raises, but the texbook says the opposite : R of (R1//R2) > R of (R1).
    Am I right or I've missed something
    (i've built this circuit on my breadboard and it works the way i said...)
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    Maybe when a very old carbon composition resistor burns it turns into charcoal that has a lower resistance than before. Whatever caused R2 to overheat will also cause R1 to overheat and become a low resistance. The pcb will also probably turn into charcoal (if it is cheap phenolic) and then will have a low resistance.
    martin1512 likes this.
  3. martin1512
    Apr 17, 2011
    Hmm, yea, but, by burning i meant something like disconneting, disappearing, "turning off" not literaly burning...
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    A modern carbon film or metal film resistor has a helix of its resistive material. If it is overloaded then it burns open so it "disappears".
    The book is probably wrong.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, you left out a critical item....
    Here's a link to the chapter you're talking about:
    http://www.allaboutcircuits.com/vol_1/chpt_7/4.html
    The critical text:
    Realistically, about the only way a "real-world" resistor would become shorted is if a blob of solder shorted across it, or something else shorted it out like a stray piece of wire. Resistors almost always fail by burning open.
    But going along with the scenario, if R2 shorted out, then R1//R2 = 0; so the total resistance would be (R1//R2)--(R3//R4) = (R1//0)--(R3//R4) = 0--(R3//R4) = R3//R4; which is about as far as we can go with that as the values for R3 and R4 have not been defined.
