7.2 voltage indicator
Ubi
Joined Aug 14, 2015
I'm trying to make a voltage Indicator light for 2, 7.2 lithium batterys. Each battery set is 7.2 volts and 1700 MHa each battery. Id like to use a dual Bi-Color LED 5mm that would light up green when the battery is between 8.2 to 7.7. Then orange between 7.6 to 7.2 then red from 7.2 to 6.6. I had read on the Internet were it said to use a LM358 op-amp I'm not sure if I can use it. Any suggestions would be great fully appreciated.
