6v battery charger circuit problems
Gary Durst
Joined Aug 9, 2016
18
Yes, I started from scratch and rebuilt the circuit that you provided in post 37
Thanks for your help, seems like such a simple circuit but I am beating my head of the wall
Gary Durst
Joined Aug 9, 2016
18
If I short R7 out and attach the battery directly to ground I get a charge current of 130mA. When connected across R7 (100 ohm) resistor I get a chargING current of 12mA when the transistor is on and 6mA when the transistor is off
34,412
Okay.
Then 130mA is about what you should get when the circuit is in the charge mode.
When the circuit is indicating charge and R7 is in the circuit, what are the transistor base and collector voltages?
Are you certain the transistor is connected correctly?
