Hi people
I am new to this forum, so be patient with my ignorance.
I see two different devices. One is a motor which can run at 5600 rpm. Nowhere is 2900 rpm or 750 rpm mentioned.
The other is a generator which runs at 240 rpm. Again no mention of 2900 rpm or 750 rpm.
Are the two devices connected? If so, are you asking how much power the motor will consume at different speeds to run the generator at some speed provided by a gearbox or some other method?[/Q
Thanks for your reply
Have a look at this system in youtube
Omega RF5000 Electric Generator
The 2900rpm is from another motor witch i have no specs.
Well its not free because someone is got to buy it and then set it up, but from first impressions I think it could work.Is this the Free Energy Magnetic Generator?
http://knowledgeandrumors.blogspot.ca/2013/04/free-energy-magnetic-generator-omega-rf.html
Max.
I have seen this before and its amazing concept, but just trying to go around the red tape, and get one myself.Is this the Free Energy Magnetic Generator?
Max.
Yes it is a far fetched idea. In any electo-mechanical system the power out will always be less than, and in some cases much less than, the power in. A motor with an inertial load has a very different speed-torque characteristic than a motor with no load. That load will have a dramatic effect on the power consumption of the motor at any speed. BTW are you sure the motor could even turn the generator?I am assuming if I align the rotors dead center to each other and couple them together using a metal sleave. Starting the motor and reducing its speed to 240rpm it would consume far less energy, and in consequence can be fed by the generator to be self sufficient by producing far more energy to be used somewhere else.
Is this a far fetched idea?
YeahYes it is a far fetched idea. In any electo-mechanical system the power out will always be less than, and in some cases much less than, the power in. A motor with an inertial load has a very different speed-torque characteristic than a motor with no load. That load will have a dramatic effect on the power consumption of the motor at any speed. BTW are you sure the motor could even turn the generator?
Ah, the pursuit of perpetual motion is never ending............................ A motor with an inertial load has a very different speed-torque characteristic than a motor with no load. ,,,,,,,,,,,,,,,,,,,,,,,,,,,
The inertial load on a motor has no effect on the speed-torque characteristic. It will have an effect though, on the motor acceleration and deceleration.
Max.
Its not fooling anything at all, if it works it has to be natural.Sorry, but you can't fool Mother Nature. It's a scam if it claims to output more energy then you put into it.
By the way, sociopaths are very good at lying.
