Hi everyone,
Does anyone know how to make a 60 seconds stopwatch by software called logicworks??
The stopwatch should have a 2 digit output and 2 inputs: run and reset...
When the run signal is high (=1) the counter will run. When the run signal is low (=0) the counter will stop running.
When the rest signal is high (=1) the counter will be reset to 00. The counter should count from 00 to 59.
These are the required criteria... So, if someone knows how to do that, please help because I have to submit this project as soon as possible and I have no idea about how to do it!!
This is the software if someone wants it: <SNIP>
