After searching at the dictionary, I found out what does Hz means. But I have to clarify it because it might be different.
OK, our circuit breaker is rated as 240 volts 60 Hz.
So means that, if our circuit breaker is rated as 60 Hz, it means it can handle alternating current electric current that reverses 60 times in a second.
Am I correct?
Thanks!
Am I correct?
Thanks!
