60-70 volt brushless DC motor driver (Schematic)
Discussion in 'The Projects Forum' started by aamir_sheikh, Mar 8, 2014.
  1. aamir_sheikh
    Nov 19, 2013
    11
    I am trying to make a driver for a 60 volt brushless dc motor. i want to use a charge pump with IR2110. The Nmos i am using are irf 540.
    Attached is the initial schematic, of one phase.
    Do you think there is anything wrong with it?
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    What is the PWM frequency?
    You may want to go with 15v on the IR2110 VCC.
    How are you handling the commutation sensing? normally done with hall effect or equivalent method.
    Max.
  3. ronv
    Nov 12, 2008
    3,404
    1,478
  4. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
  5. aamir_sheikh
    Nov 19, 2013
    11
    hall sensing, going to use them on external interrupts of some controller with six or more pwm channels,
    why 15 volts?
    it might go 100% on duty cycle... i am just designing a module for a much bigger system, which i believe would be operating in rapid and sudden bidirectional movements. any one of the high side fet might get used for a long time without its lower fet getting turned on and subsequently not pulling VS to ground and not charging the bootstrap cap.
  6. aamir_sheikh
    Nov 19, 2013
    11
  7. ronv
    Nov 12, 2008
    3,404
    1,478
    You know aamir, the more I look at it they are both the same.
  8. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    In your 1stschematic you appear to have two charge pumps on U1 if connecting U2 as well?
    Max.
  9. aamir_sheikh
    Nov 19, 2013
    11
    I am sorry, i don't understand you, what charge pumps?
  10. aamir_sheikh
    Nov 19, 2013
    11
    the one in the Ti app note is powered from a separate railing, where as the one in Ir app note is powered when ever the high side switch is on, and voltage apppears on Vs ( i think ),
    and how would you suggest i use that design in a half-bridge configuration?
  11. aamir_sheikh
    Nov 19, 2013
    11
    Also i was thinking that in me design the 26-27 volt that would appear on VB would be reduced down to 15 by the zener, but where would the extra voltage go? would it appear on VS?
  12. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    D4 and C2 is the charge pump for the IR2110, you also show a 555 C.P.?
    The Vboost is charged when the high side is modulated and there has to be a path to common via load or opposite side on in the case of a full bridge etc in order to work.
    Max.
  13. shortbus
    Sep 30, 2009
    4,096
    1,692
    Isn't D4 and C2 the bootstrap for the IR2110? I've never seen it called a 'charge pump' before.
  14. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Yes, IR refer to it as a bootstrap, but I have always though of it as a charge pump in a way, as the Vboost capacitor charge requires the modulation or switching of the upper FET. By way of the resistor/diode/capacitor combo and a path to common.
    Maybe a little license with semantics on my part!
    Max.
    shortbus likes this.
  15. aamir_sheikh
    Nov 19, 2013
    11
    dt92-4 one works fine on bread board, but doesnt work in on a veroboard, i dont know why... :(
    Down anyone knows how VS pin should behave when lowside and high side switches are off?
    on breadboard(the circuit that works) Vs swings to .08v,
    and on veroboard, Vs is on 4 volts... why is that?
  16. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    VS should float at that point, but how do you have the load side connected?
    I am just in the process of experimenting with the full DC motor bridge ECCP module on a PIC but have not got that far in the hardware point yet.
    Max.
  17. aamir_sheikh
    Nov 19, 2013
    11
    havent connected load yet, 24 volts(drain voltage) appears on VS when i turn on the high side mosfet.
  18. aamir_sheikh
    Nov 19, 2013
    11
    just a quick update, the design in schematiccapture3 works fine, it is just like switching with transistors, I just used it in a halfbridge configuration,
    thanks to everyone who replied and helped me.
  19. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
