6 volts hot to neutral with circuit breaker off
Discussion in 'General Electronics Chat' started by Stephen Murphy, Nov 2, 2014.
  1. Stephen Murphy
    Nov 2, 2014
    I was replacing an old gfci outlet because the test button no longer worked. After I shut the circuit breaker off I checked for voltage on the line hot wire to neutral and got a reading of 6volts. Is this normal, common, or dangerous? The new gfci is working fine.
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    Your meter has a high impedance, 1M or 10M-ohm. It is possible that you are picking up stray radiation. Try putting a 1M-ohm resistor across the meter and see if the reading changes.
  3. Stephen Murphy
    Nov 2, 2014
    Sorry but am not sure how to go about doing that.
