6 temp. transmitter
Discussion in 'The Projects Forum' started by Frecc, May 8, 2011.
  1. Frecc
    May 8, 2011
    Please help me by calculating a power supply that I could use with 6 temp. transmitter ( 4 to 20 mA). thanks
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I'm guessing these are 4-20mA loop powered temperature transducers ..???
    If all six transducers link to a data logging system with a common signal ground then you would typically need a single 24V DC supply with a rating of (say) at least 150mA. If you envisage expanding the system capabilities later then add sufficient extra current rating.
  3. Frecc
    May 8, 2011
    thank you t n k
