6 lead motor hookup
Discussion in 'The Projects Forum' started by jokermachine, Feb 1, 2007.
  1. jokermachine
    Feb 1, 2007
    Can anyone take a stab at this. I am hooking up a 120/240, single phase, motor for a drill press. The hookup diagram is missing, but here's what it shows. It has 6 leads numbered 1,2,3,4,5 and 8. I need the 120v hookup diagram. any takers? I'm not at the motor right now, but I recall it being 9.5 amps at 120. Thanks, Marty.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Without knowing things like if it's capacitor start/capacitor run or split capacitor, it's pretty hard to tell. Can you look up a similar model from the manufacturer for a better guess?
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Partnumber, model number etc?
  4. wireaddict
    Nov 1, 2006
    133
    I had a connection diagram but I couldn't upload it because of its size so I'll try ro describe it. Incidentally, it's for a capacitor start motor, probably 0.5 hp.
    Leads 1 & 2=run winding #1; leads 3,4=run winding #2; leads 5,8=centrifugal switch, cap & start winding, all in series. For 120V, connect leads 1,3,8 to to one power lead & 2,4,5 to the other. If motor runs backwards, reverse the start string, leads 5 & 8.
