6-24 volts buzzer
Discussion in 'The Projects Forum' started by Lightfire, Apr 18, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    I purchased 6-24 volts last weeks or so.
    So, it can be used by a 12 volts battery? Right?
    I had problem for the push-button switch. I can't find any push-button that is rated for 12 volts DC. Most are for AC rated about 250 volts.
    So, guys, is it OK to use those AC push-button switches???
    Thanks a lot!!!
  2. JDT
    Feb 12, 2009
    658
    85
    Quite OK. This is the Maximum Voltage rating.
