5x7 Dot matrix Display Counter...
Discussion in 'Embedded Systems and Microcontrollers' started by RRITESH KAKKAR, Dec 26, 2014.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I have this 5x7 Dot matrix Display but can't find its data sheet i want to make up down counter on it....
  2. shteii01
    Feb 19, 2010
    3,496
    511
    Good luck.
    hexreader likes this.
  3. ErnieM
    Apr 24, 2011
    7,433
    1,623
    And you are basing your design on an orphan component because... ?
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Orphan joking
    Actually i was getting 4 inch 7 Segment, it was not available so i just checked this the benefit from this module is that it will display name also..
  5. nerdegutta
    Dec 15, 2009
    2,565
    805
    Ok, that is a statement. I'm not sure why the members should care...
    But if you want to find the datasheet, why not change the statement to a question, and perhaps add a photo?
  6. shteii01
    Feb 19, 2010
    3,496
    511
    That sounds wonderful.
  7. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    thats not normally a big deal have you heard of a so-called DMM?
  8. JWHassler
    Member
    Sep 25, 2013
    204
    34
    There are only a few pinouts available. Do do some research i.e., slog through the Digikey catalog looking at datasheets.
    Use a DMM like the man said. You seem to have access to a computer: use it.
    This is tedious, not difficult.
