5volts into .52 volts?
Discussion in 'The Projects Forum' started by dmc0162, Mar 24, 2008.
  1. dmc0162
    Thread Starter Active Member
    Dec 13, 2007
    51
    I need to find a way to make a 5 volt power source into .52 volts. What are some ways that I can do this?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Any solution depends on the application of the 520 millivolts. If it's just a reference, use a 1000 ohm trim pot.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What is the amount of current that you need at 0.52V?
