Hi, what I'm looking to do is driver a 12V LED array with a microcontroller (Arduino). The output is a 5VDC digital PWM signal (40mA max) and I would need that signal to be amplified to a run the 12VDC LED with the PWM so I can dim it.
Alternatively, I could use the 5V analog out on the microcontroller to a analog-to-PWM converter and then amplify the output to 12V (or amplify them convert to PWM).
My project is I want to use an Arduino to run 12V LED lights that slowly change intensity over the course of the day to simulate sunrise and sunset.
Any ideas?
Any ideas?
