5v Voltage Regulator
Discussion in 'The Projects Forum' started by Leccy-Lee, Aug 17, 2008.
  1. Leccy-Lee
    Aug 2, 2008
    22
    Sorry bit of a dumb beginners question..
    A schematic i am using asks for a LM7805, but all my suppliers have is a L7805CV. Looking at Data sheet i believe it is still ok to substitute? Couldn't see what the M and CV differences made?
  2. kammenos
    Aug 3, 2008
    127
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Different manufacturers often use trailing letters with different meanings. This can be very confusing until you can find the datasheet from the manufacturer.
    While datasheet search sites are handy, you should always go to the manufacturer's site to download their most current datasheets for the parts you're considering purchasing; you may discover that specifications have changed, the part has been discontinued, or there are better parts that you can substitute.
  4. dogstail
    Member
    May 8, 2008
    10
    L7805CV provides 1.5A
    LM7805 provides 1A you can get a little more with good heat sink. Also thermal cutout and short circuit protect. Get both data sheets and compare depends what you making the regulator for to supply.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    All 7805 regulators in a TO-220 case are the same. They have excellent spec's up to a 1A load but still work not as good up to 1.5A.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I think an LM7805T gets you a TO-3 can and 1.5 amps with a heatsink.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    No, look atr the datasheet.
    An LM7805T is in a TO-220 case.
    An LM7805K is in a TO-3 case.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Why didn't I remember that?
  9. Leccy-Lee
    Aug 2, 2008
    22
    Thanks guys, my circuit for now will only run 700mA so that should do fine. :)
