5V to 12V DC:DC Circuit
Discussion in 'The Projects Forum' started by dj_johnnyg, Jun 20, 2009.
  1. dj_johnnyg
    Jun 20, 2009
    Hi All,
    Been scratching my head over this for a few weeks now, and finally had the courage to sign up & ask the experts.
    I am wanting to run a small PC in an arcade machine.
    The PC is going to be run from a picoPSU, which converts all the necessary voltages for the PC from a single 12V input. The input current is 5A.
    Now, the PSU I have in the arcade cabinet has the following outputs:
    3.3V@12A, 5V@10A, 12V@2A
    My initial thought was to use a 5V to 12V DC to DC converter, such as the
    AM2D-0512. The issue is that the output current is only 167mA.
    Can I just use a transistor (or Darlington Pair) to up the current, or am I going about this totally the wrong way.
    Many Thanks
    John
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Is there some reason why the PC (understood as meaning Personal Computer) does not have a functional power supply? Most PC supplies output dual polarity voltages, such as +/- 5VDC, +/-12 VDC.
    Perhaps I have misunderstood what -
    - means.
  3. dj_johnnyg
    Jun 20, 2009
    I have a Sega Arcade machine, which has a SUN PSU giving the outputs mentioned above.
    I have a case from an old Arcade Game motherboard (Sega Naomi) which I am putting a mini-itx motherboard into, to run some older arcade games.
    To make things easier for me, and to avoid having to have multiple PSUs in the cabinet, I want to use the PSU in the cabinet to run the PC.
    If the 12V supply had a high enough current, then I'd have no issues, but I need to get a 5A 12V output from any of the PSU outputs, so I can run the PicoPSU.
    So basically I need to get 12V 5A DC from any of the following:
    Cheers
    John
    P.S.
    You are correct, PC - Personal Computer
  4. steinar96
    Apr 18, 2009
    239
    You say you need 12V, 5A. Thats 60W of power. Proplem is
    3.3V@12 is ~ 40W
    5V@10A ~ 50W
    12V@2A ~ 24W
    Technicly if you could settle for ~ 12V, 4A you could use a dc:dc converter on the 5V@10A output and thus end up with aprox 45W if its pretty efficient.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    You'd need a 5v to 12v boost converter that's at least 96% efficient at 4A output. That's going to be difficult to find.
