+/- 5v Regulated Power Supply
Discussion in 'The Projects Forum' started by wellyboot, Jul 17, 2008.
  1. wellyboot
    Jun 1, 2005
    16
    Hi
    Im looking for a simple regulated split rail power supply (+5v GND -5v) from a 12-15v DC supply
    Its for a low current application <100mA, but the +5v rail will supply more components (ie Pic chip/real time clock/LCD ect) so will have more current flow, the -5v supply only feeding the negative supply rail on a op-amp and a sensor.
    I did see a diagram a while back that used a 7805 and 7905 5v regulator ICs, but cant remember where it is!
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    To do what you're wanting the original power supply will have to be floating though, no ground. This is because you want to establish a ground after the fact.
  4. weije1986
    Member
    Apr 19, 2008
    14
    search the datashet of LM7805 . Inside that datasheet should have information if i not mistaken :)
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    I have pinouts for several popular chips in my PaintCAD, which you can download off my blog.
  6. Tahmid
    Jul 2, 2008
    344
    27
    Wellyboot,
    This is a common +/- 5v 0.75A power supply. It is cheap and easy to make, but safe to use and very reliable. Hope it will fulfill your requirement. Instead of 100mA, I have given a circuit with 0.75A. If you require less than 100mA, you can use the 78L05 and 79L05 instead of the 7805 and 7905 shown in the schematic. 7805 and 7905 are found in TO220 package and 78L05 and 79L05 are found in TO92 package.
    _____________________________________________________________________________
    The strongest man in the world is one, who stands alone for achieving something good.
    পৃথিবীতে সেই সবচেয়ে শক্তিশালী ব্যক্তি, যে ভাল কিছু অর্জনের জন্য একাই নিরন্তর চেষ্টা চালিয়ে যায়।
  7. Tahmid
    Jul 2, 2008
    344
    27
    The earlier attachment was a circuit from mains. The one attached here is from 12-15v dc source. It is shown for 1A, but if you require 100mA, you can use 1W zeners.
    __________________________________________________ ____________________________________
  8. wellyboot
    Jun 1, 2005
    16
    Hi Guys
    Thanks very much for the replys so far, havnt had chance to try any of them yet, but will be soon
    Thanks again
    Dave
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    It can be iffy, you have to load them down some, but computer power supplies have all those voltages. Being switchers they also have a lot of ripple on them.
