I am working on a battery charger that uses 2 potentiometers to control battery undervoltage setpoint and charge current. When the pots are adjusted they affect the 5 volt reference, that is accurate when the power stage is not connected to the rest of the circuit, which in turn affects my 2.5V reference. The 5 volt reference moves with with different potentiometer settings from 5v to ~3.7v. I am at a loss for how to fix it without completely redoing the power stage by splitting all the outputs of the transformer and use diodes. I just realized that this was happening and, although, the circuit still functions it affects performance. I would appreciate any help!!!
