Hi there,
I am wanting to make a +/- 5V power supply, but need a centre tap transformer (I think!) -- similar to the following design:
http://www.reconnsworld.com/power/multipowersupply.gif
The only problem is that I don't have a centre tap transformer, but just a normal two-winding step down transformer.
Edit: another question on the side:
If I have a raw signal of about 0.1-1uV coming in to a band pass filter, is it better to amplify it (by about 1000) before or after the filter?
- Is it possible to use a normal transformer as a centre tap transformer? Or how else can I get -5V out?
- Also, is the 100uF cap on the output neccessary?
